u joint seal
picker523
I understand changing a u joint seal can be tricky. Do I really need a manual for this? Do I need to have it in gear to pull the drive shaft from the housing after undoing casle nut ?
Don S
Re: u joint seal
What are you working on?
Changing a ujoint seal means you need to replace the complete ujoint, not just the seal, and there are 4 of them per ujoint.
If you have to ask, then yes.
Have no idea what you're talking about.
picker523
Re: u joint seal
I'm sorry Admiral... I've got a Merc alpha , and I'm asking about changing the seal behind the u joint because my bellows have apparently leaked, so I'm changing the gimble bearing and all bellows .The kit comes with the u joint seal so I thought I should change it since there was water in the outdrive foot. What do you think?
Don S
Re: u joint seal
Well, if you have an Alpha drive (and not an Alpha I Gen II drive) here is a link to the free online manual that you can look at.
Section 3A gives details on replacing the seal and resetting the rolling torque.
http://www.boatfix.com/merc/Servmanl/6/6covr3.pdf
As far as having the drive in forward, that if for removing the drive from the boat, not disassembling the upper.
See section 2 for removal and installation instructions.
picker523
Re: u joint seal
Don... Is this something I purchase online to read? I can't seem to get it to open up. Thanks for your help.
rodbolt
Re: u joint seal
snatch it apart, beat it back together, use plenty of silicone, it will be ok.
I will try better tomorrow:)
follow DonS advice.
read the manual, then read it again.
study it for your constitutionals. then twist a wrench.
this aint rocket science but the damage from lack of maint is as expesive as improprer maint.
and trust me it can be a budjet buster.
its the only reason I post but its getting harder and harder.
Don S
Re: u joint seal
No, it's a free online manual like I stated earlier. Just move your cursor over the cover page, notice it changes to a finger when over the big red box? Click it. Then you will go to the index. Then move your cursor over the index page and find the links to the different sections.
If you have Adobe Acrobat Reader version 6 or newer you can save the file to your computer. Some of them are fairly large, so give them time.
picker523
Re: u joint seal
Don... I got it to work, I think the problem was , it took so long to open up after klicking a section ,I assumed it wasn't working. Changing that seal behind the u joint looks pretty complicated but I'll do it if I have to...the question is ,do I have to? I believe the drive shaft bellows was leaking , but will exposure to water ruin that seal? Will a pressure check reveal the answer? thanks
searay3
Re: u joint seal
That seal keeps oil in, not water out. It is very possible it is still ok if the bellows were leaking. You are correct, pressure test the drive.
bruceb58
Re: u joint seal
Unless the water that got in corroded the surface that the seal runs on. Should probably check to see if the surface is still clean.
