fossildave
- Oct 18, 2005
- 16
Just replaced head gasket on 3.0 Litre 4 cyl engine. Only put anti-seize on head bolt threads. Did not use Quicksilver Perfect Seal as shop manual suggested. (Looked like anti-seize was previously applied) Is this a fatal error? Is Perfect Seal needed to prevent water seepage past threads? If so perhaps I can remove one bolt at a time, clean and replace with proper sealant. Final torque was 130 ft/lbs per manual. I have not installed valve cover & ex manifold yet. Please post suggestions.
