Re: carb assembly replacement compatibility
There's a general rule of thumb that you can use with carbs. The larger the venturi, the more top rpm you'll have. The tradeoff is acceleration. The smaller the venturi's, the more acceleration. The trade off is top rpm's. You can see where we use that on race boats and performance boats that have pretty constant loads. With recreational boats you have to factor in differences in loads and the motor's ability to carry a heavier load from time to time. This is why we factor in intended use.
If your boat is used for skiing, you'll be looking for acceleration rather than top end. If it's a performance hull, you'll most likely be looking for top rpm.
As for performance on your particular rig, it's hard to say what effect bigger carbs will have unless we know more about your set up. If you're set up in the low to mid 5000 range the largest carbs probably won't do much except help get rid of weight in the gas tank faster. If you're set up close to 6000, they may help some.
You also need to factor in the port timing of the 79 100. It won't be as aggressive as the same year 140.
The later the carbs you use, the closer they will be calibrated for the fuel we have today.
