I've got a 1984 Avanti with a 1.7L Mercruiser (4 cyl). I noticed that it was running a bit rough while cruising at lowest speed. Upon inspection of spark plugs I noticed that a small amount of water is seeping through the plug closest to the back of the engine (sorry, not sure what # plug that is). I noticed water was seeping through slowly both while the boat was running as well as after I had stopped the engine. I would mop up the water with a rag & it would come back through the plug again slowly (without engine power). It's definately water, although I did detect some gas odor as well. I also checked the oil and don't see that the oil is "milky". I didn't run the motor long after noticing the plug leaking (just long enough to get it pulled out of the water at nearby boat ramp). What could cause water in the plug, and is this a really, really bad thing?
A day before I noticed the water seeping out of the plug (I had the boat docked at the lake), the boat started taking on more water than usual and had gotten up almost to the engine overnight. I pumped it out as soon as possible, of course, but was wondering if somehow the engine could have taken in some water and that could be why it's seeping through the plug?
I found out that the water is coming from the screws in the transom holding on the prop...could this be the boot leaking (that I had replaced just 2 years ago?!). Shouldn't boots (or bellows?) last longer than a couple of years?
Thanks for taking the time to read over my problem!! I hope that I provided enough detail (or not too much either). ~ Cowgrl
