  #1
Old November 7th, 2006, 10:26 PM
outboardnut outboardnut is offline
Default 1980 9.9 HP Evinrude jumps out of gear
Hi all. I have a 1980 Evinrude outboard that is jumping out of gear when under load. Scared the P out of me the first time it did it.
From what I've gathered from lurking around here it's the "clutch dogs" that cause this. I believe I'm an above average shadetree mechanic, and really want to tear into her. Couple of questions before I do though:
1. Is the average Joe capable of doing this without having OMC special tool # @@!@#$. How hard is it?
2. What's the real name of the part I need? I was able to pull up a Bombardiar diagram here: http://epc.brp.com/default.aspx?bran...alerlocator=no
but did not see a "clutch dog".
  #2
Old November 7th, 2006, 11:21 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: 1980 9.9 HP Evinrude jumps out of gear
look at item 12 on the parts list. you will have to have a oem manual, click literature on the brp site. or hunt it on ebay. i suggest you read the manual several times, and decide if you can do it.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old November 8th, 2006, 10:11 AM
steelespike steelespike is offline
In the gearcase diagram part 12 refered to as shifter clutch dog These gearcases are much more difficult than the old 2 piece ones.In my after market manual the only reference to a special tool is "using suitable puller remove the bearing housing"As suggested previously an OEM manual is best and no repairs should be attempted without a manual.You may find a manual at the library.
  #4
Old November 8th, 2006, 10:27 AM
Silvertip Silvertip is offline
Before diving into the lower unit, disconnect the shift cable and shift manually. If the problem goes away, its a cable adjustment problem, not the lower unit. One thing is certain however, continue running it that way and it will be a lower unit problem.
  #5
Old November 8th, 2006, 11:14 AM
i assumed being a 9.9 it was not remote controlled.
__________________
FLORIDA GATORS
TEBOW Country
  #6
Old November 8th, 2006, 11:32 AM
R.Johnson R.Johnson is offline
Before taking anything apart, adjust the shift linkage as discribed in the service manual. Hopefully that will cure the problem. I have seen very little problem with the 9.9, and 15 gearcases.
  #7
Old November 8th, 2006, 12:24 PM
It's a tiller handle, manual shift. I dropped the lower and made sure the linkage going to it was right...and it was engaging in forward gear.
I just checked the price of the part....got $69.25. If I have to roll the dice I would say replacing the part would be cheaper than buying an untested EBay unit....
I'm off to the shop to see if I can get to the clutch dog shifter. If I screw something up before buying the parts I'm just out a non-working lower unit. Thanks for all the replies, stay tuned for the thrilling conclusion!
  #8
Old November 8th, 2006, 12:43 PM
  #9
Old November 8th, 2006, 01:16 PM
If you replace the clutch dog, you will have to check the shift link adjustment's, including the shift rod in the gearcase. Why not do this first, and see if you can save $70.
  #10
Old November 8th, 2006, 01:53 PM
Well it took me about 30 minutes to get to it. Looks like it will probably take me about 3 hours to get it back together lol. Well I snapped some pics to see what yall think of the critical internal parts. Forward gear is on the left, second picture shows the other side of the clutch dog. Click on thumbnails to enlarge.
  #11
Old November 8th, 2006, 02:02 PM
I have larger pictures on file and will be glad to snap more if needed.
  #12
Old November 8th, 2006, 02:40 PM
It's really hard to tell from the pic's. I would have tried the shift adjustment. You will have to adjust that lower shift rod when you put it back together.
  #13
Old November 9th, 2006, 03:03 PM
Well I managed to get the lower unit back together. I double checked the shift linkage adjustment according to my book...1.6mm to 10.5MM....installed lower and went to the lake.
It's still jumping out of gear. But we have some new info now. If I hold forward on the shift lever it will not jump out of gear.
I'm thining about just using a bungie cord to hold the lever forward....unless anyone else has any ideas
. I'm also thinking about trying to change the shift linkage a little to cheat it a little...backing the shift rod out about 4 turns to see if it cures it. Any thoughts on that?
  #14
Old November 10th, 2006, 01:08 PM
I think the bungie will cause premature wear of the yolk and clutch dog groove etc
Manual says Screw shift rod into dhift lever and yoke then back out until bent upper portion is forward and flat side of coupler is toward the drive shaft.shift to neutral measure from top of coupler to mating surface of gearcase should be 13/32 to 7/16 of an inch.May be obtained by turning the rod.
^ Another prime example of the need to have a service manual.
Even before I knew which gear was forward I thought the forward gear looked worn.Maybe it's just the light.
Are the detent balls present and working?
  #15
Old November 10th, 2006, 02:22 PM
Detent balls are present and working. It feels like a good solid shift into forward, neutral, and reverse. I set the shift linkage according to spec and it still jumped out of gear.
I then dropped lower and examined the hole shift linkage and bell crank thing carefully. It appears to me that the shift linkage adjustment really isn't that important on this motor. If the lower unit is not installed or hooked up the shift lever rotates freely forwards and backwards...there are no stops. There is enough free play travel in the shift lever forwards and backwardsto make the shift rod adjustment not critical. i.e. if the unit is in either forward or reverse...you can still push on the handle farther.
I went ahead and backed the shift rod out a few turns...which would actually give forward gear a better chance if this adjutment mattered...and it still jumped out of gear. My best conclusion is the internal parts of the gearcase are worn. I'm afraid to just replace the clutch dog without replacing everything else relevant inside there which equals a lot of green.
I took the motor for a one hour cruise last night...did fine with the bungie holding the lever forward. It wins for now I guess.
  #16
Old November 10th, 2006, 02:36 PM
iwombat's Avatar
iwombat iwombat is offline
Just looking at the pictures I'd say you're in for a new forward gear and probably a clutch dog. Why not take the parts into a repair shop and have a mechanic take a looksee? Probably won't cost you anything to get a pronouncement of death on the right parts.
  #17
Old June 2nd, 2009, 11:35 AM
apember apember is offline
I have the same problem with my 1980 15 hp. I did not have this problem until I recently had someone replace the seals in the lower unit for me. After I got the motor back, it now jumps out of gear. I has never done this before. Is it possible the the guy who did the work for me did not put everything back together correctly which is causing the problem. Last night I dropped the lower unit to check the shift rod height above the lower unit case, and the rod is three mm too high. I tried to screw it in, but after a 1/4 turn, the threads end and it will not turn in any farther. This makes me suspect that something is not assembled correctly if I cannot get the rod adjusted to the proper height. I am afaid to run the motor because I do not want to damage gears when it pops in and out of gear at full speed. Is it possible the one of the parts is in backwords or is there only one way that things can fit?
Thanks in advance for any advice.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1990 Evinrude 115 jumps out of gear powerse Johnson & Evinrude Outboards 2 September 26th, 2006 07:45 AM
35 hp 84 Evinrude jumps out of forward gear Johntree Johnson & Evinrude Outboards 3 April 6th, 2006 05:03 PM
74 Evinrude Jumps out of gear Dale Kelly Johnson & Evinrude Outboards 3 October 4th, 2005 07:17 AM
79 Evinrude jumps out of gear Swede Johnson & Evinrude Outboards 0 July 29th, 2001 04:26 PM
35 hp evinrude jumps out of gear robdro Boat Topics and Questions (not engine topics) 1 May 30th, 2001 10:29 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
