double check the DIP switch settings, sometimes I have to toggle them.
the redwhite wire in the fuel management harness if its laying in the wet bilge can and will trigger the water in the fuel alarm even if its not hooked up.
for testing the TPS
first verify a 5V rverence, orange to black. then use a manual setting or an analog meter to verify a smooth transition from idle,about.62V to wot about 3-3.5V. most digital meters will try to scale at about 3 V blk to pink.
digital meters are awkward to deal with sometimes.
be aware that the test harness colors dont match the engine wire harness clors
it bites many a good tech.
I made my own with the correct colors
