Loose Wire ID
tylertown
I found a loose wire hanging down under the power head on my 1995 15 hp Evinrude on the port side. It appears to have been attached to a bolt with a crimped on connection that does not show signs of a recent break. I can't trace it. Is this a ground wire? I thought it might possibly be for the kill switch but that works ok.
fireman57
Re: Loose Wire ID
What color is it? If it is black it probably is a ground. Stretch the wire around and see if there is a hole that the bolt will reach to go back in.
