I have a 1995 Evinrude 175hp motor that I just had to change out the rectifier/regulator. I thought the tach wasn't working because of the rectifier. But after changing out the rectifier it still didn't work. Tach stuck on 2000 rpm's and would not move. Went out and bought a used tach and put it on. The tach zero's out when the key is turned on. And when cranking the motor the tach goes up to about 500 rpm's. But when the motor starts it goes back to zero. I am getting 13v at the purple and 5.5v at the gray signal lead. Could it be another bad tach? Or could something else be causing it.
Thanks,
Robert
Thanks,
Robert
