Re: Point Gap for an older 45 hp Crysler Motor (4.5) maybe
This is from the clymer manual
Turn the point set adjusting screw to obtain a gap of 0.020 inch. when measured with a flat feeler gauge. The gap is correct when the feeler gauge offers a slight drag as it is slipped between the points. When the gap is correct, tighten the hold down screw securely and recheck the point gap. Rotate the crankshaft clockwise 2 full revolutions and recheck the point gap.
