imported_Jake
- Sep 5, 2006
- 6
I have a 1993 25 hp 2 stroke mercury outboard that has been a wonderful motor until recently. It starts "ok" but has a rough idle and at idle it sounds like it's running on one cylinder but I'm told by the mechanic both cylinders have fire. At high rpm's it runs fine and never gives me a problem but sometimes (now often) after I've run it for a while and bring it back down to idle it stalls and it's a real BUGGER to get started. When it starts acting like this I usually have to wait 15 to 20 minutes befor it will start again. It has never left me stranded, yet, but I'm loosing confidence fast. And then sometimes, although usually not, it runs fine.
- Sounds like the carburator: I've had it rebuilt.
- Sounds like the coils or plugs: I've replaced them.
- Sounds like bad fuel: It's not, I'm religous about keeping the fuel fresh with the proper oil mixture and using Stabil and yes the vent is open.
- Sounds like the themostat: It's not that either, I had it and the water pump replaced at the same time.
I am at my wits end and at this point can't find a mechanic that can diagnose the problem but they say it will probably be at least another $500 in repairs.
Gentlemen - Your help and any sage advice would be greatly aprreciated.
Thanks, Jake.
Thanks, Jake.
