  #1
Old October 30th, 2006, 09:34 PM
Walleye5150 Walleye5150 is offline
Default 67, 68 3.9 mercury am I missing a part on carb or ?
I have takin small gas engine repair 4 years in high school but haven't worked on a boat engine before. I just traded a 22 mag pistol for this engine and I plan on fixing this and I don't know nothing about it so I thought I would ask. With the cover off and where the gas line hooks up inside there is nothing over the gas line inlet is that the way it suppose to be. I'll see if this picture thing works. I'll try to post a picture.
File Type: jpg 000_1678.JPG (61 Bytes, 12 views)
  #2
Old October 30th, 2006, 09:47 PM
AMD Rules's Avatar
AMD Rules AMD Rules is offline
Default Re: 67, 68 3.9 mercury am I missing a part on carb or ?
Shoot me an email with the pic. I have three of those motors, and might be able to help.
Either way, I can post the pic for ya.
/AMD
__________________
'72 Glastron GT160 c/w '72, '84 and '86 Merc 115hp
'67 Merc 3.9hp , '70 Merc 9.8hp, '61 Merc 50hp ... The Merc Nut
  #3
Old October 30th, 2006, 09:58 PM
Give me your email address it won't let me attach to this forum email sorry Thanks AMD
  #4
Old October 30th, 2006, 10:34 PM
AMD Rules's Avatar
It is a spot for a rubber grommet to seat. The upper cowl houses the recoil for the starter, and needs to be tight against the lower cowl. The rubber grommet that is mounted in the upper cowl allows the fit to be be tight, yet flexible.
Click to see larger image
__________________
  #5
Old October 30th, 2006, 10:39 PM
Thanks AMD For posting my picture. Looking straight down it's where the big hole is, than a smaller hole sits in it, thats where the gas line hooks up right or am I wrong.
  #6
Old October 30th, 2006, 10:50 PM
AMD Rules's Avatar
The fuel fitting is beneath that round hole, sticking out the front side. The round hole you see is not related to the fuel connection at all.
In the image below you can see the rubber grommets under the cowl that I was referring to.
Hope that helps.
__________________
  #7
I thought it was missing a part the way the butterfly works on carb , Well anyways I took the sparkplug out and there was a small hole on piston not all the way threw it, should I put new piston and rings in or what ?
  #8
Old October 30th, 2006, 10:58 PM
AMD Rules's Avatar
They're known to be an exceptionally reliable motor. Unfortunately you have a motor built many, many years ago. You need to evaluate the condition of the entire motor, including the lower unit to see if it would be worth the time/money to fix it. Parts are increasingly difficult to get for it. You might be better off looking for a donor motor.
Good luck either way.
__________________
  #9
Old October 30th, 2006, 11:00 PM
Ok I see what your saying the fuel line had hole in it all the way threw it when you looked down it went all the way threw it I guess it is old lol look like fuel flowed threw that and another part was missing to carb
  #10
Old October 30th, 2006, 11:02 PM
Worn out fuel lines
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
missing part on carb x308 Johnson & Evinrude Outboards 4 July 7th, 2006 04:21 PM
What is the missing part? robtherep Johnson & Evinrude Outboards 4 November 27th, 2005 07:22 PM
25 hp missing part?? johnjay28 Johnson & Evinrude Outboards 6 August 16th, 2004 11:37 PM
missing part ID 38plymouth Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 0 May 15th, 2003 10:45 AM
MISSING PART? JCCHRISTOPHER Non-Repair Outboard Discussions 9 February 3rd, 2003 02:23 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
