1986 Johnson 90 h.p. rough idle
rbickham
I posted before about my rough idle problem. It has new rings and the carbs rebuilt. I took it back to the dealer i bought it from and complained, he said he would fix it for free! I picked it up today, didn`t get to talk to mechanic, but the counter person said it was ready to go. So i don`t know what they replaced. I took the cover off, looks like they replaced all four coils. I put it in the water today, it runs alot better and it was idling a little fast, so i backed it off. I noticed they had the idle adjust screw almost all the way in. Why would it have to be almost maxed out?
Solittle
Re: 1986 Johnson 90 h.p. rough idle
What is the idle rpm with the boat in the water - - ie. not on muffs? Should be around 700 rpm I think. Are the thermostats in? If not the engine will not get to operating temp and will idle rough.
Texasmark
And the 700 rpm is in F gear (engine loaded). d:)
Mark
rbickham
Mark
I will check RPM`s and thermostats.
Thank Youd:)
