How do you run this motor? Do you do a lot of putting around at trolling speed? I found that switching to a hotter, but still recommended spark plug on my '87 20hp stopped any fouling. A leaner fuel mix can do the same, but I'm not suggesting it.
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
run motor at different speeds, not much trolling...just starts missing after 3-5 minutes ofslow running and fous the plug
80 PSI compression is on the low side. Should be over 100 and closer to 120 - 135. Before getting to carried away, decarb the engine as was suggested. SeaFoam and Deep Creep are the same product only Deep Creep is the spray version. It can be found at most auto stores and farm stores that sell auto parts. Your marine dealer may also have it but it will be more expensive (typically). Search this forum on how to do a Decarb. That removes carbon that may be causing ring sticking. When the engine loses power, immediately check for spark on the dead cylinder. You may have a coil or power pack going bad. Run a can of SeaFoam (not Deep Creep) in a tank of gas. See if that helps.
Tried seafoam....put in lake...have same problem...going to hotter plug...cross reference to Champion L78CJ4 is DENSO W24FS-U....anybody familiar with this plug?
