1991 OMC shifter handle loose
loricarl94
We just bought this boat and the shifter handle is loose. Does anyone know how to tighten it? Also the power trim gauge doesn't work. Any ideas? Thanks in advance.
dodge1971340
Re: 1991 OMC shifter handle loose
Hi! there should be a lock screw on the lower or on the sides of the handle were it gose on the shaft its usely allen head. as for the trim gage it could be a # things wireing, sender, or the gage its self. i would try the wire ing first. there might be a wire broke. you would have to be elect inclined to brake it down. Good luck!! Dodge
loricarl94
loricarl94
Thank you! We are going to go out and check those things right now! This site is GREAT!!
lakelivin
My money a.f.a. the trim guage is on a faulty trim sender....
If you do a search in this forum on 'OMC trim sender' I think there were some past posts telling how to test whether it is good or not.
loricarl94
loricarl94
Thank you! That's good advice, I appreciate your info.
