  #1
Old October 24th, 2006, 08:45 AM
rifleman_maynard rifleman_maynard is offline
Default Evinrude 6hp Fisherman 1970 Cooling system questions
Is this motor supposed to have a pee hole?
What temp should the thermostat open?
When started in the tank water starts spraying from the ~1/2in hole a few inches above the cavitation plate after about 15 seconds of running. Over the next 30 or so seconds the spray gets stronger. This is not a steady stream but a spray of droplets combined with exhaust? gas. The heads warm up until I can hold my hand on them maybe 3 or 4 seconds.
The thermostat, when removed and tested in a pan of water with a meat thermometer starts to open at 140 and is fully open at 160F.
Is this correct behaviour? The motor runs really well since I rebuilt the fuel pump. I would not want to fry it and I have no confidence that it was maintained correctly before I bought it.
My manual was on the way until ebay suspended the seller before we could finish the transaction. :^ I will try again.
  #2
Old October 24th, 2006, 09:52 AM
freddyray21 freddyray21 is offline
Default Re: Evinrude 6hp Fisherman 1970 Cooling system questions
The thermostat is opening properly. My 65 does not have a pee hole and it's does have water out of the exhaust holes like your's does. I can hold my hand on the head for longer than that though. I would check to make sure the passageways going for the impeller through the block are all clear. If it's been awhile change the impeller.
  #3
Old October 24th, 2006, 10:31 AM
steelespike steelespike is offline
Classic discription of hand on head is "too hot to hold your hand on but not so hot it burns you".
Carefully check while running under load.
If you don't know the age of the impeller or suspect it could be old you should replace it.Cheap insurance for a healthy motor.
  #4
Old October 24th, 2006, 05:53 PM
I bought the motor a few weeks ago and several things that the seller told me turned out not to be so. Like about how well it ran. In fact, it did run well if you kept squeezing the bulb.
If I had paid much for it, I might be annoyed. On the other hand, I am enjoying the process of getting it right.
My testing tank is a 5 gallon bucket. Possibly I don't have enough of the shaft covered. If the weekend looks nice, I may take it out and see if running it on the boat makes a difference. I may put in a water pump kit just on GP.
  #5
Old October 24th, 2006, 09:13 PM
hey rifleman where you at in Missouri? I use a 55 gallon trash can. You need to have the intake covered good
  #6
Old October 25th, 2006, 07:13 AM
F_R F_R is offline
You can't expect it to work properly in a 5 gallon bucket. Get it in the water.
  #7
Old October 25th, 2006, 08:59 AM
My thought was that if the intakes were well covered (they were) it would work. This is why I love the internet, information like this tends not to get into manuals and articles.
Thanks, I'll either take it to the lake or get a bigger tank.
  #8
Old October 25th, 2006, 09:05 AM
Quote:
I am West of Clinton, near the west end of the Grand River arm of Truman Lake.
  #9
Old October 25th, 2006, 09:14 AM
ah I used to live in Warrensburg, I'm over in St Louis now
  #10
Old October 25th, 2006, 12:34 PM
BF BF is offline
I'd do the water pump anyway. I have a 70's version of that motor, and the impeller hadn't been changed in years. It seemed to pump OK, but pumped noticibly more with a new impeller in it. The rubber takes a set after years and doesn't pump as well. FYI, these motors are a bit funny in that there is a roll pin near the top end of the driveshaft (is perpendicular to the shaft). When you go to drop the lower unit, it'll go down 1/2 inch and then get caught on that pin. In order to drop the lower unit completely off, you need to turn either the driveshaft (turn prop with it in gear) or the flywheel so that the roll pin lines up with a slot up at the bottom of the motor (which you can't see). Just keep turning and jiggling the lower unit slowly until it lines up and drops.
There is no tell-tale... the sputtering of water out that back hole is how it's suppossed to be.
good luck..
  #11
Old April 5th, 2009, 12:22 PM
morgane morgane is offline
I have a 63 5.5hp Fisherman. Runs great but only get warm exhaust out of the exhaust port. Motor doesn't get too hot to put hand on tho. How long does it take for the thermostat to open. I just purchased this for $25 and the motor looks brand new. Very well maintained. All new wires, plugs, fuel lines. So, I gotta believe the impeller has been changed out at some time. I ran it in a 5 gallon bucket with the inlets covered. But I'll try a bigger one too. Not running it long or at WOT throttle until I resolve this. This is a sweet little motor that's been exceptionally well maintained. BTW, I am runnning 24/1 mix.
Ed
  #12
Old April 5th, 2009, 12:55 PM
tx1961whaler tx1961whaler is offline
Welcome to iboats!
Next time, please start a new thread instead of reviving a 2 year old one.
Anyway, the lower unit has to be submerged at least half way up the leg when in a barrel or trash can. A 5 gallon bucket is not enough.
If you don't know how old the impeller is, it is a good idea to change it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1993 140 Cooling System Questions mudd_mickey Johnson & Evinrude Outboards 8 March 20th, 2007 09:33 PM
400 Stringer - cooling system questions mattsmall1972 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 21 August 4th, 2006 04:02 PM
Evinrude cooling system Sounder Non-Repair Outboard Discussions 2 January 26th, 2004 03:57 PM
Evinrude 5.5 Fisherman: Age & Cooling ?'s veluxman Johnson & Evinrude Outboards 2 July 30th, 2003 11:31 AM
1970 6hp Evinrude Fisherman(need help) trollfish Johnson & Evinrude Outboards 7 May 9th, 2002 05:02 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
