  #1
Old October 22nd, 2006, 10:46 PM
fpelton fpelton is offline
Default 2003 Yamaha 40hp 4 stroke bogging
Have a new to me 2003 yamaha 40 4 stroke.
I boat the engine yesterday and ran it for the first time today. It was winterized prior to the sale.
It runs great at a low idle and can get up rpms under no load. When in the water, when I throttle it up it bogs down and cuts out. If I nudge it up slowly, eventually I can get it up on a plan and run like heck. If I power down and try to power up quickly, it bogs down or completely stalls out.
Any thoughts?
Bob
  #2
Old October 22nd, 2006, 11:02 PM
rodbolt rodbolt is offline
Default Re: 2003 Yamaha 40hp 4 stroke bogging
sounds like its time to clean the carbs paying speacial attention to the acceleration enrichment circuits.
you should also check for fuel restrictions with a vacum guage and a T fitting installed just in front of the fuel pump intake, vacum should be less than 4" Hg and at least about 1/2" Hg at or near WPT.
  #3
Old October 22nd, 2006, 11:03 PM
make WPT a WOT
  #4
Old October 22nd, 2006, 11:16 PM
Thanks for the tips. What is "WPT" ?
  #5
Old October 22nd, 2006, 11:25 PM
wpt was a typo.
but if I try to use the edit function my poor machine all but shuts down so I dont normally.
why didnt ya read the second reply ?
  #6
Old October 23rd, 2006, 08:40 AM
Now I get it. Thank you.
The engine is an 04, not and 03. The carbs were just cleaned, new fuel filter and a fuel/water separator added. When I recieved the boat, the tanks were dry. I started with fresh fuel, also filling the separator prior to hooking up the fuel lines.
  #7
Old October 23rd, 2006, 09:22 PM
test spark, test compression, then go chase fuel.
I dont care if the carbs were brand new this morning,if they got trash in them this afternoon Guess what ?
its Suck,Squeeze,Bang and Blow. been that way for over 100 years.
when a gasoline engine,especially a 4 stroke, has a rapid opening of the throttle you MUST add extra fuel or a POP or total stall will result regardless of anyother issues.
as you stated with a gradual throttle opening it runs well I dont suspect compression or spark issues but they should be tested.
the chemically correct burn mix of gasoline is about 14/1 air to fuel. at about 16 to 1 the mix becomes to rich to ignite, at about 13to 1 it becomes to lean to burn. as its a constant volume fuel you must add or subtract fuel with the throttle opening.
diesel is a constant combustion type fuel and does not require air throttling and will burn in a 300-1 range from high to low.
gas is about a 3-1 range.
so based on your description when you open the throttle rapidly either there is not enough fuel in the fuel bowls for extra enrichment or the acceleration circuits are defective/dirty.
  #8
Old October 25th, 2006, 01:41 PM
rpelton rpelton is offline
Default Rebuilding Carb ( was: Re: 2003 Yamaha 40hp 4 stroke bogging
I'm considering rebuilding the triple decker carbs. I have rebuilt lots of carbs on lawnmowers, chainsaws and chevy engines, so I am hoping that I am not getting involved in something that I shouldn't. Any suggestions before I start. Can I get a carb kit from this site.
Thanks Bob
  #9
Old November 3rd, 2006, 03:41 PM
Default Re: 2004 Yamaha 40hp 4 stroke bogging
Have implemented all suggestions.
Spark check out
compression checks out
Fuel pump pressure is good
Carb rebuilt
Changed all filters, 6 gal tank, checked little titty on fuel line (and it is nice and firm when squeezed) - just like the old days.
How about timing? I have a light, but not the know how.
Or, is it time I bite the bullet and bring it in?
Thanks again,
Bob
The motor still dies out when doing a "hole-shot" (really fast acceleration).
The only thing I have not done is timing. I have a timing light, but
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2003 15hp YAMAHA 4 stroke sharkman Yamaha & Suzuki Outboards 3 December 2nd, 2006 08:32 AM
2003 Yamaha 115 2 stroke dorkhead Yamaha & Suzuki Outboards 4 March 13th, 2006 12:07 PM
2003 Yamaha 115 (2 Stroke) Ancient Angler Yamaha & Suzuki Outboards 1 December 14th, 2005 07:55 PM
YAMAHA 80 4 STROKE 2003 MOD TIMING? tommynor Yamaha & Suzuki Outboards 13 April 29th, 2005 05:11 AM
2003 Yamaha 115 four stroke oil leak zuru Yamaha & Suzuki Outboards 5 November 5th, 2003 04:52 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
