ok gentleman, i have a 1986 johnson v6 with WOT issues. i have done the obvious things like check the fuel filter, replaced some leaking fuel line. in addition i rebuilt the carbs, checked the link and sync the best i can, checked compression (95 on each cylinder), replaced the coils and packs. i'm at my wits end, the engine will rev get when it is in neutral (can take it up to 5500 rpm or so by hand operating the throttle) even had a friend put it in a tank to run while in gear and it does fine there also but when it gets under a load i can only get about 3000 rpm WOT. anyone have any other suggestions???? i've even check all the ground wires to make sure they are clean and tight. tried to slam the throttle wide open and tried to ease into it and still the same result. any help or suggestions would be greatly appreciated. gettin close to taking it to the local dealer for diagonsis.
