  #1
Old October 17th, 2006, 11:14 PM
owenr owenr is offline
Default Mercury Motor missing 60 HP 4 stroke
I have a 2005 60 hp mercury 4 stroke that is giving out of gas when running at 3/4 to full throttle. It will shut off and I will pump the bulb a few times and crank up and go again for 1 to 2 minutes and it does it again. What could be the problem. I did replace the bulb and the gas line with no change. This motor is in a 2005 Bass Tracker with a 21 gallon gas tank. Thanks in advance.
  #2
Old October 17th, 2006, 11:58 PM
JUSTINTIME's Avatar
JUSTINTIME JUSTINTIME is offline
Default Re: Mercury Motor missing 60 HP 4 stroke
sounds like carbs are not adjusted or timing
check your vent line for kinks same thing with fuel lines
__________________
HUMAN BUILT = HUMAN FIXED
CERTIFIED MARINE TECH
  #3
Old October 18th, 2006, 07:59 AM
Dunaruna's Avatar
Dunaruna Dunaruna is offline
Send a message via Skype™ to Dunaruna
[colour=blue]Hi owenr, welcome to iboats!!
Is your motor carb or EFI?
__________________
Watch this space......................
  #4
Old October 18th, 2006, 04:18 PM
It is EFI. Fuel lines are OK. I even replace the bulb on the line attached to the buld. A dealer said he though it would be the fuel pump going bad. What do you think?? It is a brand new motor.
  #5
Old October 18th, 2006, 05:30 PM
Dunaruna's Avatar
[colour=blue]EFI mercs run 2 fuel pumps, a mechanical one (low presure) and an electric one (high pressure). The primer bulb is no longer required - the system is self priming.
I suspect a low pressure pump failure BUT these engines have a big bucket full of electronics and an equal amount of testing equipment. You need to get her to an authorised dealer for diagnosis. It's under warranty, not even worth lifting the hood, let merc deal with it.
If you have an external fuel/water filter, change that first - it is not a warranty item.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
9.9 Yamaha 4 stroke intermittent missing Catspaw Yamaha & Suzuki Outboards 3 July 24th, 2008 06:58 PM
mercury mariner 95 4 stroke. Is this a good motor???? DOES IT HAVE A MERC POWER RMOE Mercury & Mariner Outboards 3 April 17th, 2005 05:46 AM
New Johnson 115HP 4-stroke missing at hi-RPM? tony_cliffy Johnson & Evinrude Outboards 20 January 25th, 2004 04:28 AM
9.9 hp Yamaha 4 stroke missing at temp gybe98 Yamaha & Suzuki Outboards 2 September 4th, 2003 05:25 AM
2000 Mercury 90 4-stroke missing KD4JKK Mercury & Mariner Outboards 2 September 1st, 2003 07:33 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
