O-rings on lower end fill and vent screws?
crunch
Napa gave me O-rings instead of gaskets (gaskets are what came out of it).... will O-rings work?
Thanx.
crunch
Re: O-rings on lower end fill and vent screws?
Thanx Vlad, I kinda thought they would, but didn't want to change oil twice :)
timmathis
NAPA sold you the right ones. Better safe than sorry...
twocycle
Whao dude! O Rings will not work correctly if yours takes gaskets. The way to tell is to look at the underneath side of the screw heads and if they're flat then use gaskets, if they're grooved then use O Rings. That's the problem when you go to some place that's not familiar with what they're selling parts for - they don't know anymore than what a freakin' book tells them cuz they don't have the experience. Unless the customer is sure what to get or what it is they need best go to a dealer than is familiar with the product. After over 35 years in this business as a marine tech and shop owner I can tell you a few stories!
Happy boating.
John
Owner/Operator
UB&M
lisfisher
what is the make and serial number of your engine?
crunch
1978 Merc 800 SN 4835014.... and there were no grooves on the screws :'(
lisfisher
having trouble with your serial number....what horsepower is it??
emckelvy
Your motor does not take O-rings stock, unless someone has changed the drain/vent plugs and I doubt that very much.
The correct gaskets for your application are either Sierra P/N 18-2945, or Mercury P/N 12-19183-3, at around $.70 each for the Merc part.
Your local Napa should be able to get the Sierra part for you.
HTH..........ed
timmathis
They are right if it was made for o rings. o rings or gaskets will work. But if it is made for gaskets it needs gaskets. It depends like said above what type screws you have.
crunch
Thanx guys, I'll take the vent screw down to Napa again and see if they have the gaskets in stock, if not I've written down the part #s d:)
