I wanted to get some recommendations concerning what material to use in creating a new dashboard for my gauges. I have an old 1980 Bayliner Cuddy and the plastic dash holding the guages is old, warped, and cracked. I would like to make a new dash to replace it. Have not been able to find anything premade that is even remotely close.
The material must be light weight, about 1/2 to 3/4 inch thick, and must be easily cut and shaped with normal home tools. i.e. drills saber saw, etc.
Wood is the obvious 1st choice, but what kind? And what do you seal it with? I would not mind plastic, but that does not seem readily available and its tougher to work with.
Any recommendations? And if it is something not found at Home Depot please let me know where you can buy it?
Thanks
Thanks
