Quote:
Originally Posted by Texasmark
What shifter? The remote control?
Take the remote cables off the engine. With the throttle at idle, slowly slide (attempt to slide) the shift arm thru FNR while rotating the prop by hand.....required to get into R. If that won't work, get back on here.
Mark
let me attempt to clarify. First, the boat did shift to FNR when we got it home. Since then, we had to take the motor off to do some work in the transom. Put the motor back on and now the shifter (next to the steering wheel) will o to FNR, but the prop always stays in forward., All we have done is disconnect the battery, remove the motor, replace same motor, adjust the shift tension, reconnect the battery and now the prop stays in forward even when we shift to neutral or reverse.
