motorrad11
- Aug 24, 2006
- 3
I've pulled my hair out and spent almost as much as I paid for the boat trying to figure this out. I have a 78 Terry 15ft bassboat with Mercury 850. I have a 4 blade 17 pitch prop. It ran great for 4 years after I bought it, GPS read 39-40mph with two 200 pound guys it it. Reverse went out and the mechanic said it would be cheaper to put on a used lower unit than replace the gears. So....he put on the used lower unit and when I put it on the water it it would get up to around 1800 rpm and bog out. had the cables replaced, the carbs rebuilt and still 1800 rpm is all I will get. It will bog around all day at 1800 but will not go higher. The mechanic who rebuilt the carbs (not the one who replaced the LU) hooked it to a dyno and said it was putting out something like 78hp at the prop shaft. He suggested that the new LU may have a differnt gear ratio than the old one and I need a new prop with 15 or 13 pitch. Before I spend another $115 on a boondoggle, can anyone give me some advice? It is killing me as I love the boat and it ran soooo good before this ordeal started. Thanks and this is a great resource.
