Re: OMC Sail Drive Zephyr 1984
Thanks Captain... It happened after a maintenance... carburetor cleaning.unfortunately I have not the maintenance manual.two question:
1)The ignition switch is not so old (2 years), Point "M" is the stop circuit, How can I check if it work correctly ?
2)Could you said to me if the "ignition Feed wire is the Black/Yellow" this cable end at the Starter Solenoid and have a 20 amp fuse?.
Thanks for your help again. Hec.
