Re: Timing on XP150
1st, I was having trouble finding Joe's Method via search, but I did come across his email, so I sent him an email to get it. I also asked about the quick start and was told my engine shouldn't have that feature. If someone thinks I do, then I need to know. The manual doesn't seem to mention it either.
2nd, I don't think the internals of this motor had ever been touched prior to me rebuilding it and I didn't change anything except once over on the piston size(s).
My engine is E150STLCD and I believe my heads are 332545 (I grabbed that from another post of mine). Are these the lower compression heads, meaning I should have a different timing? If so, what?
It also appears the carbs are stock setup. I rebuilt them and all the orifice's were numbered the same as the parts catalog. The only thing in question on these carbs was the valve seat. The one in the kit had a different sized opening than the one on the carb(s). I didn't replace it.
I also use the plugs called for by the manual.
