  #1
Old October 4th, 2006, 03:37 PM
jackhartjr jackhartjr is offline
Default Evinrude 'Simplex' Remote Control
Hi folks, was wondering if anyone out there has an Evenrude 'Simplex' Remote?
Mine is on an Oday 22 built in 1975.
It has steering and throttle control.
If so I would like to quiz you on it. I want to make it work on a 9.9 Evinrude.
Thanks in advance.
  #2
Old October 4th, 2006, 04:26 PM
F_R F_R is offline
Default Re: Evinrude 'Simplex' Remote Control
What's the question? It takes an adapter kit to connect it to the motor if that's what you mean. There probably aren't too many of those adapter kits around.
  #3
Old October 4th, 2006, 05:45 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
what year is the 9.9
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #4
Old October 4th, 2006, 05:53 PM
I am wondering how it connects to the motor, you wouldn't have a photo of the connections would you?
My e-mail is jackhartjr@aol.com
You can call me at 828-310-8111
What does the little knob on the top do, also the one on the left as you are looking at it.
I have a starter switch just above the remote.
It is a 75' model boat, I just got an 85' Evenrude 9.9 Yachtwin motor which was designed for sailboats.
F__R, you wouldn't have an idea where I could find one of the adaptor kits...or start looking would you? I actually have the two cables that go to the engine.
Thanks again in advance.
Jack
  #5
Old October 4th, 2006, 07:17 PM
mikesea mikesea is offline
You may have to rube Golberg it.The shifter is easier. Just forward of the shift handle you MAY see two indents that are ,or could be drilled and tapped to accept the hardware for the shifter assy. The throttle,well,first look at the throttle linkage rod that connects up under the flywheel on the port side ,inside the eng.At the foot of that MIGHT be a curved arm with a pin that doesnt seem to do anything,pointing upward. IF it's there,that is where you would attache the throttle ,the kind with the stainless slide over clip.Then forward ,in the cowling pan ,might be tappings.like I described on the shifter ,to accept the throttle cable to secure it.I believe the handle must be removed so as to gain access for the cable.My suggestion is to find an engine ready to go,but the sailmasters and the like ,SOME were ready for almost any application,If you have a patient OMC dealer,he should be able to get the parts.It could be costly,so you might look for a motor ,on EBAY perhaps,mabe a blown eng ,where you could swap your powerhead,P/h swap would be easier I think.
  #6
Old October 4th, 2006, 09:49 PM
Hi Mike, it appears this one came ready to accept the kits, am looking for the parts now. The shifter will mount just like you said. For the throttle I remove the Stop Switch, mount the cable there and I am pretty sure it attaches like you said. Thanks to all for the replys.
Jack
  #7
Old October 4th, 2006, 10:59 PM
F_R F_R is offline
You can see the parts involved and get the part numbers on-line. Copy and past this into your browser (without the quotation marks
"http://epc.brp.com/default.aspx?brands=ej&lang=E" When you get there, select O B Accessories from the Products drop-down list.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1997 Evinrude Remote Control ddiebel Non-Repair Outboard Discussions 2 August 22nd, 2004 09:34 AM
Remote Control 4 evinrude 65 hp triumph edrowe Johnson & Evinrude Outboards 1 April 6th, 2003 08:54 PM
OMC Remote Control for 98 Evinrude 50 HP RCCola Johnson & Evinrude Outboards 3 November 10th, 2002 03:28 PM
Wiring on Evinrude Remote Control G DANE Johnson & Evinrude Outboards 4 March 18th, 2002 12:26 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
