Water pressure gauge on outboard!
deerhound
After much advise I have now fitted temperature guage to my Evinrude BE40ELCR 40hp, (not run in water yet) and some comments were made about fitting a water pressure gauge? can anyone please advise me on fitting same, anything will help, many thanks JBD
Reel Poor
Re: Water pressure gauge on outboard!
Just install a T fitting into the tell tail hose and connect the hose for the guage.
ricksrster
Hardware kits are usually included.
SiggiJo
If you do a search on Water Pressure Gauge, you will see quite a few posts on this subject. I have both water pressure gauge and temp gauge on my Evinrude and consider both essential. The wps will monitor the health of your impeller and you can quickly see any changes in pressure to alert you to any potential overheat problems before the temp gauge starts to rise - so it's a kind of double insurance for not cooking your engine. Also if your water intake gets blocked, you can see it straight away.
Like Real Poor said, they are easy to install. I got my T-fitting from Halfords - they sell them for car window washes and they are just the right size. The gauge I bought on Ebay, but most chandlers should have them. I have OMC on mine, but I think Teleflex makes them also.
The water does not actually travel up the tube to the gauge, it just compresses the air in the tube and that's how you get the reading on the gauge. I've got mine next to the temp gauge, so I can quickly scan them both at the same time and then you don't have to worry about checking your telltail all the time. Good luck!
deerhound
Fine all noted, I wonder how your boating is coming along since I last communicated via this site,? My own boat is fine, I was very surprised at the performance on my 40hp, have had it showing 37mph on GPS in flat calm in sea, not thinking much about sinking which I was pre-occupied with, really enjoying it, these chaps on iboats are most helpfull I dont think there is another site like it? JBD Happy boating.
