Boomyal
- Aug 16, 2003
- 12,072
I want to find a manual pump that can be used to pump gasoline out of one tank and into another tank. Currently I have what is referred to as a lift/siphon hand pump. It is virtually worthless other than for syphoning purposes.
Often times when you want to pump gas out of one tank into another, the tanks are not at the right elevations to siphon. iboats has one like I have and that does not cut the mustard. This item should be portable and easily stowable.
