Re: Hydrofoil or not ?
In my experience, foils are typically a band-aid solution to another problem. These problems can include: an underpowered rig, a hull with defects of some sort (hook, rocker, dents, algae growth, etc.), running the wrong prop, improper loading/weight distribution of the boat, improper set-up of the motor to the boat (too high, low on transom), etc.
If you have eliminated all of the above possibilities as causes for poor performance, then a foil MAY help your situation...
- Scott
