Re: Relay or Trim switch??
Lisfisher, There are PTT systems with one or two solenoids. I will presume your reference to the relay means the solenoid, since there is no relay. You need to jumper the solenoid secondary (red wire from battery) to the non-black (non-ground) wire on the solenoid primary (small terminal) winding. If the trim works well, you have a bad switch or bad trim limit switch. if the up is intermittent, jumper across the solenoid secondary (battey cable to blue wire). If the motor works well, you have a bad solenoid.
How well does your trim work if you push both middle and top buttons ar the same time?
