I'm new to boat engines, been working on cars all my life. I bought a 1961 uniflite runabout with a 1956 30hp johnson (and 4 other similar engines in various stages of repair). It wasn't running right so I checked the points and found one had a hold down screw hole that was stripped. So....I replaced the armature plate - that was interesting. I cleaned everything along the way and regreased the plate bearing collar etc. When I put it together I found I couldn't rotate the plate unless the four attaching screws were very loose which does not seem to be correct. Any ideas?
