  #1
Old October 1st, 2006, 08:35 PM
merlefitz merlefitz is offline
Default 1996 mariner slipping in full throttle
I have a 50hp that slipps like the prop stops turning.
When taking off with a pontoon boat, the prop turns fine but when you nail the throttle it immediately comes out of gear, (so to speak).
I have tried three known good props including a newly rebuilt prop and the all do the same thing. I tried them on another boat and they are all O.K. so it is not the props.
I removed the lower unit and checked the drive shalf, I removed the lower gears and there is no sign of wear down there.
Can the lower unit gears slip?
When watching the prop area in the water, everything looks perfict, when you mash the throttle, there is a serious immediate slip or snap out of gear and the motor will run up the RPMs but the boat slows down.
Seems like the prop is turning 2,000 rpms and the motor is turning 5,000 rpms.:'(
  #2
Old October 1st, 2006, 10:43 PM
akwalker's Avatar
akwalker akwalker is offline
Default Re: 1996 mariner slipping in full throttle
Where is the AV plate in relation to the keel line of the boat? Sounds like the motor isn't in the water deep enough
__________________
1987 Bayliner Ciera 2150
5.0 OMC Cobra
Snug Harbor, Sylvan Beach
  #3
Old October 2nd, 2006, 12:12 AM
roscoe's Avatar
roscoe roscoe is offline
Is this a new problem?
Shift cable or shift linkage may be out of adjustment, and not throwing it fully into gear. It will pop out under heavy load.
  #4
Old October 2nd, 2006, 08:58 AM
The motor came with the boat in 96 so I would think the lower unit is the proper length and when I watched it as it "came out" the prop was still under water.
I will check the shift cable position today.
anything else?:$
  #5
Old October 2nd, 2006, 01:43 PM
Quote:
Origional motor, unknown when the problem started but it had a new driveshalf put in and not run since. The other thing is that it shifts really hard, especially into reverse, I thought that could be from sitting three years.
  #6
Old October 3rd, 2006, 09:50 AM
I adjusted the shift linkage as suggested and it only took 4-5 turns and it made the diffrence I was looking for.
Works great.
The Admiral gets the cegar.
Thanks a lot folks I appreciate it.
Merle
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1996 Johnson 9.9 loses power on full throttle WaveWalker Johnson & Evinrude Outboards 3 August 4th, 2009 05:33 PM
40 hp mariner won't run at full throttle boatman03 Mercury & Mariner Outboards 4 April 28th, 2005 10:15 AM
evinrude 150 Full throttle, high rpms, like slipping clutch olemiss_biogirl Johnson & Evinrude Outboards 1 July 11th, 2004 04:50 PM
Mariner Dies At Full Throttle pete wylie Mercury & Mariner Outboards 1 June 6th, 2003 07:31 AM
20 hp Evinrude slipping @ full throttle shaggy Johnson & Evinrude Outboards 2 May 1st, 2003 09:32 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
