Quote:
Originally Posted by rodbolt
that engine uses whats known as a waste spark sysrem.
it fires 1and4 and 2 and 3 in simultaneous pairs.
have a leak down test run as a compression test isnt very accurate for that engine.
have you performed the resistance tests as per the tune up spec guide.
i would lean towards fuel as an issue if 4 can jump a 7/16ths gap.
Thanks for the reply,
I didn't know it was called a waste spark system but I gathered they fire in simultaneous pairs. That was what led me to swap the plug wires for 1 and 4 to verify that the problem was consistently the #4 cylinder.
I haven't performed any factory specified tests as I ordered a factory service manual but haven't recieved it yet. I have a manual I bought at westmarine that covers a multitude of yamahas and mercurys but the attention to detail on specific models is quite disappointing.
I may pull apart the carb one more time and verify I am not missing anything but once the factory service manual arrives I will do any and all diagnostic/troubleshooting tests they recommend.
What types of fuel system issues would cause a wet sparkplug (extremely rich) other than a sticking float and needle valve assembly? The yamaha mechanic set the idle mixtures for me when he synced the carbs and the #4 carb was 2 1/2 turns out. I tried it in a variety of settings with no improvement in results.
Keep the ideas coming, This is driving me nuts.
Thank you,
Karl
