Re: 1973 Evinrude 40Hp seems to run on one cylinder only
The primer bulb sucking flat is a sign of a clogged, or closed, fuel tank vent.
Was the 2nd plug wet with drops of water or fuel?
If fuel, switch the coil assembly from cylinder to cylinder and see if the spark moves from one cylinder to the other.
