new owner
troye
I have just purchased a 1976 Evinrude 9.9 model # 10624. I have been shore fishing and saltwater fishing but I am new to using small boats and outboards. I need to be sure this little outboard is circulating water well. I placed the earmuffs on the intake and water spits out but does not stream out as I expected (one hole at the rear just below the engine cover). Also, there appears to be an intake in two low locations. I think they are sperated by the trim area. Is there a cooling system for the motor and a seperate one for the drive system? Please feel free to share the proper terms for the parts i am trying to describe.
thanks
troy
Xcusme
Re: new owner
Two cooling systems?? Nope , just one system.Water enters near lower unit at intake ports, into water pump (just above lower unit and midsection junction). Water pump is driven by the spinning drive shaft. Water is pumped up a copper tube to the powerhead. Water circulates through cooling passages in powerhead and exits down through lower leg and out thru the prop hub. A thermostat in the power head regulates the temperature of cooling water through the powerhead. Water that spits out the idle relief port (rear-below cowling) is an indication that the pump is working. If you can hold your finger on the motor head for a few seconds, it's not overheating. If this is a new to you motor, you'd be wise to replace the water pump impeller (spinning pump part that pushes/pumps the water). As the impellers age, they can get brittle and come apart. Bits can be pushed up into the power head, clogging up the works. Change the lower unit lube. If the old lube is milky, there's water intrusion into the lower unit (not a good thing). Try running the motor on a boat at the lake or in a barrel of water. Use enough water to cover the water pump (lower unit-mid section junction). Using the muffs is alright, but, you're forcing water past the water pump and isn't a clear indication of the condition of the water pumps efficiency.
Most here will tell you to find a OEM service manual for your motor. All service and maintanance routines are clearly outlined with pictures!
troye
Re: new owner
thanks. I have ordered the manual and will take her out this weekend for a spin. I appreciate the detailed feedback.
