rockfishAL
- Aug 15, 2006
- 2
Last Sunday I started my Force 85 without any problem and ran for about 10 minutes in the Chesapeak Bay. I was running it very slow since I was trolling when the engine stopped. I put it in neutral and turned the key. I only heard click coming from the starter but it never crancked the fly wheel. The small starter gear is still engaged to the fly wheel. Is this normal or should the starter gear disengage when you stop turnning the key?
I cleaned the battery terminal and made sure that the battery is good since the Bilage and the tilt still works. Please help, is this a bad starter? I thought the fly wheel may be stuck and tried to turn it by hand while in neutral but it was not bugging at all. Should I be able to turn the fly wheel while it is in neutral?
