I recently purchased a boat with a 1954 Evinrude 15hp motor. The recoil sticks when trying to start. The rope does not go back in. I took the recoil mechanism off, cleaned it with WD40. When I loosen the center bolt holding the spring grippers on, the recoil will go back in. The spring seems to be good, as the recoil will go in and out. It feels strong. However, when I loosen the center bolt, the mechanism slips eventually and then the head grippers don't extend and retrack as they should to spin the motor head. It's like the center bolt, when fully tightened, is causing the rope/recoil to stick. When I loosen it, the recoil doesn't stick, but then the mechanism slips and the head grippers don't grab to rotate the motor to start. Any advice would be great. By the way, being 52 years old, the motor may not be as strong as it should, but it runs great! They built things to last back then. No plastic!
Any suggestions?
Thanks - Bryan
Any suggestions?
Thanks - Bryan
