80 hp merc. piston removal
delsol
i think i wrist pin bad or piston slap. can you remove it on the motor 3 cly 89 80 hp merc
delsol
Re: 80 hp merc. piston removal
maybe someone can answer this how hard is the power head to remove compared to 135 johnson i removed a couple yrs ago. i misplace shop manual in my home
bob
Chris1956
Delsol, The piston can certainly be removed from that motor. It should be easier than your V-4 Johnson, since it is less cylinders and weight.
Normally, 2-cycle motors do not have obvious piston slap or a bad piston pin. The piston pin usually has needle bearings, which are very tough.
delsol
chris i took power head off.the manual is a little confusing. do i have to remove crankshaft to take pistons out. it looks that way in book. the shop manual is poor imo. compared to autos and other stuff.
thanks
bob
lilmandavis
the crank, pistons and rods come out as an assy.
Chris1956
DELSOL, The cylinder head does not come off on that motor. So, you cannot remove the connecting rod bearing cap and pull the piston out. You can remove all the bearing caps and roller bearing and leave the pistons in, if you want.
