  #1
Old September 24th, 2006, 08:58 AM
kspilot kspilot is offline
Default evinrude 200xp broken rod/piston?
I bought a 92 stratos with a broken rod/piston. If your looking at the back of the engine, it would be the bottom one on the port side. I was curios as what could be the cause and is this something that a non-mechanic can tackle with limited tools etc. What would be the hours entailed to change out the one piston and rod if possible? Would this be something that all the psitons should be done? I am new at this as far as outboard engines....this is my first one!
  #2
Old September 24th, 2006, 09:48 PM
Solittle Solittle is offline
Default Re: evinrude 200xp broken rod/piston?
A big welcome your way ks - -
Do you have the OMC shop manual specific for your engine? If not get one.
Yes a driveway wrench can overhaul one of these but it is a bit more involved than changing a tire on your car. The engine needs to be removed, disassembled, taken to a marine machine shop, machine work done as needed, lotsa other parts bought/cleaned/inspected, and the thing put back together.
If you want to check it out further before taking the leap spend as much time as you can reading the posts here in this section. Thousands of questions have been asked and answered here and they are waiting for you.
  #3
Old September 25th, 2006, 09:06 AM
Silvertip Silvertip is offline
Whether or not the engine is even rebuildable is a question at this point. Until you get it apart and see how much damage there is you simply don't know what you are dealing with. If a rod is broken, there could be some substantial block damage that can't be repaired. I hope you bought this boat cheap.
  #4
Old September 28th, 2006, 11:16 PM
Quote:
Thanks for the info. I took the head off and the sleeve is shot with fragments of the piston in the lower ports. The wrist pin looked melted on one end and it appeared to go past the sleeve and may have damaged the block. I am wondering should I replace the powerhead or buy a new 07' 150 horse evinrude and would that perform as well on my 20 ft stratos as the rebuilt 200.
  #5
Old September 30th, 2006, 09:55 AM
emdsapmgr emdsapmgr is offline
Anytime you give up 50 horsepower, you will see a performance difference. It may be even more than 50 HP if you have the "XP" engine. It will put out up to 10% more hp than indicated on the cowl. Your engine is probably a 90 degree big displacement engine. The 150 is a 60-degree smaller bore engine, but weighs less. When you compare new vs. rebuild, you need to evaluate the $ you will spend for the performance you want in the boat. FYI, Evinrude makes both blocks in a 200 hp ETEC version.
  #6
Old September 30th, 2006, 11:12 AM
One additional bit of advice is if you do decide to rebuild, make sure you have determined what caused the failure. Lean mixture, overheat, and lack of lubrication (failed oil pump) are all possibilities. Rebuilding the engine and not checking the supporting systems is a recipe for doing the job again.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Broken piston 89 65 voodoo Johnson & Evinrude Outboards 3 July 4th, 2006 10:07 PM
broken piston ring caper_45ca Johnson & Evinrude Outboards 9 September 1st, 2005 01:38 PM
140 Evinrude - broken piston ring, piston expansion? andys15 Johnson & Evinrude Outboards 23 July 25th, 2005 08:42 AM
'87 Merc 3.0L - Broken Piston Skirt rdc54yty Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 April 20th, 2005 08:37 AM
Broken Piston Eric Eberlin Johnson & Evinrude Outboards 4 August 18th, 2004 07:50 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
