Re: Will not crank, no fire
Being you have a merc ignition, you will have to figure out which manual would best suit the motor/ign package. I guess there is a verbage issue for me here. When you say won't crank, I was getting the starter would not turn the motor. Seems it turns over fine but will not fire/run. If it ran and no longer does, first thing is the tuneup. 25 hrs doesn't mean much. Check compression, if you haven't already. Replace the coil with the proper one for your ign system. It's cheap. Cap/rotor/plugs/wires. Fuel filters, water seperator etc. While your in the distributor, look at the pickup coil. Merc used a metal base (oem) and they rusted and stopped working. There is a replacement I got from the merc dealer here, (yes i had this issue), that has a bakalite body, costs half as much and has no metal to deteriorate. I don't have my manuals here, but there is a testing procedure for the pickup coil. The modules are another issue. I am not aware of any testing that can be done. At least the merc dealer here states that. He also told me that it either works or doesn't. I found that to be untrue. Mine ran, but ran like crap. After a complete ign service, paid the 400 bucks for the new module and all was well. Trouble is everything in the ignition has to be ruled out or your taking a 400 dollar gamble. Once you rule out the ignition, the carb/fuel would be next.
