Took the boat out this afternoon with some of my coworkers. The boat started, but sputtered to a stop within a minute as I was loading people. Restarting worked, but would work for shorter and shorter periods of time. Eventually, it wouldn't restart. Sniffing the carb proved that there was no fuel.
I've had a problem like this before that was solved (maybe not?) by changing the anti-siphon valve. So, I jumpered the fuel pump relay and heard the pump run for a few moments and come to a slow stop. I tried to pull off the fuel filter but it wouldn't budge (by hand). I put this on myself a month ago, and know that it was not that tight and the gasket was oiled. The only thing that I can think of is that the fuel pump was pulling a vaccum on the intake side of the pump. Opening the fitting to the metal fuel line proved that there was no fuel in the system.
I opened up the access plate to the top of the tank and rapped on the check valve a bit (some frustration was evident). This seemed to fix the problem as I was able to jumper the pump and get fuel up to the output side of the pump. I put everything back together and the boat ran just fine.
Is this a normal failure of an anti-siphon valve? The previous one seemed to leak back to the tank if I didn't use the boat for a couple of weeks. The last time that we used the boat prior to this evening was 3 days ago and it ran just fine.
Your thoughts and ideas will be appreciated.
johnbo
johnbo
