OK i tried another tach and it says the same thing, i do not doubt your word on a 90 not turning that many rpm's. so i guess the next question is where does the rpm signal come from. it must be getting the wrong signal, right?
i have just read the very informative post by walleyehead in the frequently asked questions and his knowledge matches all the available text that is on the manufacturers and prop sites. and i still can't get my prop right. i have a 1998 suntracker signature pontoon with a 1999 merc 90 hp. i got the boat used but in great visual shape. it came with a 15 pitch prop just as the tracker factory book says it should. first time in the water it had terrible performance. it felt as though it was pushing water and felt and looked nose down. trimming did not help and it blew out with minor adjustments up on the tilt. also the rpm's were over spec at nearly 7000. i went to a 17 with some improvement and about 200 rpm drop. so i tried a 19, still better and the nose was coming up and i had more trim use but still to high on rpm. it came down about 100 more. next step was a 24, because it was available. this one is steel where the others were aluminum. and it came from a 90 hp merc on an aluminum express bass boat. still to high at 6500 and not much better feel on performance. my tach started fluctuating wildley during my test so i thought maybe the tach was bad so i borrowed one from a friend and got basicly the same reading on it but without the fluctuations. what do you think, bad rectifier?, need more pitch?, need more blades?. i never heard of a pontoon boat with this big of a prop. scratching my head.
