  #1
Old September 20th, 2006, 04:48 AM
boony boony is offline
Default 55 hp evinrude drive shaft
I have a evinrude 55 hp model 55879 s
How do i remove drive shaft to repair gear box
Cheers await reply
  #2
Old September 20th, 2006, 05:14 AM
F_R F_R is offline
Default Re: 55 hp evinrude drive shaft
If you don't know the answer to that one, you certainly need to start by getting a factory service manual before attempting to dig into that lower unit. kencook.com has the manuals.
But I will give you the courtesy of answering your question: You remove the nut off the bottom of the shaft and the bearing housing which is under the water pump. You need a special tool to properly torque the nut when reassembling.
Your motor is a 1968
  #3
Old September 20th, 2006, 05:52 AM
  #4
Old September 20th, 2006, 05:59 AM
Cheers
I have a manual but it doesn`t cover bottom end.
i`ll have to make a spanner for pinion nut, after i work out how to get to it .I`me in australia.
Thank you for your help .
Boony1
  #5
Old September 20th, 2006, 09:21 AM
R.Johnson R.Johnson is offline
That gearcase has three large snap ring's. Two, in the back to retain the prop shaft bearing carrier, and one in the front to retain the oil pump. Those ring's are bear trap strong, and need a special pliers.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1987 150 evinrude drive shaft? BrettSS Johnson & Evinrude Outboards 8 October 9th, 2005 01:09 PM
6hp evinrude drive shaft pin kingi Johnson & Evinrude Outboards 10 October 13th, 2004 04:44 AM
2 part evinrude drive shaft? inohv8 Johnson & Evinrude Outboards 3 September 17th, 2004 08:31 AM
Evinrude V6 drive shaft differences? mrichmond Johnson & Evinrude Outboards 2 May 21st, 2004 10:04 PM
Evinrude 4.5 trouble removing drive shaft peterdale Johnson & Evinrude Outboards 2 December 26th, 2002 07:43 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
