If you own a MotorGuide trolling motor, and if the direction arrow that indicates the direction the motor is pointing is broken/won't rotate; don't bother buying a replacement cover with a new arrow....it will break too.
Use two-part Loctite epoxy to fasten the turning gear to the arrow housing. Works great, lasts longer, etc.
