  #1
Old September 18th, 2006, 01:07 PM
mikes998 mikes998 is offline
Default Boat Steering/Mercury w/ Tiller Handle
I just purchased a 25 horse Mercury motor. I had a tiller handle installed on the motor because it was used with a steering wheel before. When you increase speed, the motor pulls really hard to the left. I have to put a lot of pressure on the handle to keep the motor from turning to the left. I was wondering if anyone has an idea of what would cause this?
Mikes998
  #2
Old September 18th, 2006, 01:16 PM
roscoe's Avatar
roscoe roscoe is offline
Default Re: Boat Steering/Mercury w/ Tiller Handle
Do you mean the handle moves away from the operator, to the left, making the boat turn right?
  #3
Old September 18th, 2006, 02:25 PM
Quote:
  #4
Old September 18th, 2006, 02:27 PM
Yes, that is correct. The handle goes left and the boat wants to turn to the right. When you are at slow throttle you can turn easily both ways, but when you increase speed it pulls left.
  #5
Old September 18th, 2006, 11:32 PM
roscoe's Avatar
There are two things you can play with to try to correct the problem.
In the picture below, #39 at the top, is the trim tab.
Loosen the bolt that holds it in, and move the rear edge of it to the starboard side of the boat. Tighten the bolt.
Also, there is a screw on the side of the transom bracket, number 13 below.
You can loosen or tighten this screw to put tension on the steering.
  #6
Old September 19th, 2006, 02:50 AM
deejaycee_2000's Avatar
deejaycee_2000 deejaycee_2000 is offline
tighten the tention screw on the side of the transom as in no. 13 above .... quick and easy ...
__________________
__________________________
... THE MAXIMUM HORSEPOWER IS NEVER ENOUGH ...
  #7
Old September 19th, 2006, 10:44 AM
thanks
  #8
Old September 19th, 2006, 01:05 PM
roscoe's Avatar
Hey Mike, what year is this motor?
If it does not have the tension screw, look on the front of the motor.
Just above the mounting clamps.
It may have a sliding lever.
  #9
Old September 19th, 2006, 03:01 PM
It is a 1999.
It has a lever on it to keep it from turning. It is a red handle sliding lever. I messed around with that but it did not have any effect on the pulling. When you are driving, it takes a lot of strength to keep the motor from turning. It seems to even tilt the boat when you try to maintain a straight line. I thought maybe it was something to do with the prop. I just put the motor on the boat. I did check last night to see if it was centered and it was off by a 1/2 an inch. Do you think that would cause it to pull to left real hard?
  #10
Old September 21st, 2006, 05:32 AM
jaymasta jaymasta is offline
Quote:
Originally Posted by mikes998
It is a 1999.
I don't think half an inch would make a differance, although if it isn't bolted into place it might be worth a shot to just loosen the clamps and nudge it over.
is your trim tab perfectly straight?
I was having some serious issues with my boat, leaning to one side, and always pulling the steering wheel in one direction or the other, and it felt really unsafe at times, my trim tab was perfectly straight and it rough condition, so I bought a brand new merc one and put it on and tilted it a bit to compensate for torque steer if you want to call it that the torque that is applied to the boat due the the propeller turning in one direction, anyways after playing around with it I got it so my boat tracks perfectly straight, and the steering wheel now feels very light and turns evenly in both directions.
  #11
Old September 21st, 2006, 10:33 AM
The trim tab is tilted to the right about a 1/2 inch.
  #12
Old May 18th, 2008, 12:00 AM
rabell yell rabell yell is offline
Hello , I Have A 2006 Trophy Pro 2052 ,at Slow Speeds I Drift Left Hard And Fell I Have To Over Steer To Correct .can I Adjust The Steering Or Is It Somthing Else
  #13
Old July 22nd, 2008, 04:42 PM
caslin caslin is offline
I also have a 20hp Merc, mid-1980's where the tiller pulls away from the operator. I have moved the tab above the prop to it's limit also. The prop is not in great shape, but I'm not sure that it could cause this problem.
For long trips I use the stiffness level to tighten up the steering to make it easier on my arm. I'm wondering if the tail on the bottom down-shaft is bent and is causing the problem.
Does anyone know how I could measure to see if this is the problem?
Are there any other known causes?
Thanks in advance,
Alan
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Convert tiller handle to remote steering mississippisportsman81 Yamaha & Suzuki Outboards 5 November 11th, 2007 10:41 AM
tiller handle gear for classic mercury 20 desenior88 Mercury & Mariner Outboards 3 March 2nd, 2007 12:06 AM
Does E-TEC come with tiller handle steering Lundman Johnson & Evinrude Outboards 2 September 28th, 2006 01:43 PM
converting a mercury 15hp (1997) with tiller to steering wheel airkampos Mercury & Mariner Outboards 3 August 14th, 2005 10:04 AM
Hooking up a steering wheel on a Jon boat and removing the tiller handle. Bearcamp Non-Repair Outboard Discussions 2 January 17th, 2004 03:39 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
