Hi all
I am having an intermittent problem with an 05 Honda 135 outboard on my hurricane 198re.
It happens intermittently not every time.
I will be driving in the boat or idling,doesnt matter,i will hit up or down trim and all electrical power to the motor will be cut off. The engine will stop and when i crank the key i dont even get a click to start.
I will then remove the power wires from the battery for 10 seconds and hook them back up. It then starts fine and works fine. I checked the wiring in the boat itself and it is all hooked up correctly.
I am thinking there is some sort of relay in the engine that is doing this or perhaps in the trim control? Anyone have any input on it? Like I said,it happens half the time,sometimes it doesnt happen at all,and removing the wires from the battery and rehooking them up seems to reset something and then it works fine.
