1999 Evinrude 150 Ficht
imported_BigRon
I have an oil leak problem that I have not seen until recently. After having the boat out a couple of times I had seen that there was a small amount of oil on the floor of the garage. It did not appear to be injector oil because the stuff I use is red in color. The oil appeard to be a blue green in color amd it was coming from what appeared to be a small vent hole in the lower unit. The vent hole is about half way between the cavation plate and the horizontal prop shaft on the lead edge of the motor. Has anybody else experienced this happening on there ficht engines?
emdsapmgr
Re: 1999 Evinrude 150 Ficht
This would probably be the lower unit oil. Have the gearcase pressure-checked for leaks. It may need to be resealed.
