  #1
Old September 16th, 2006, 05:46 PM
ZaTech's Avatar
ZaTech ZaTech is offline
Default Mercury 850 - no power/speed
Attempted to take the boat out again this weekend (Last weekend, motor didn't start). Got the motor going and purred like a kitten. I was very happy, I put in reverse to get away from the dock and all went well. This is where the problem occured and I'm hoping someone can help me out on this. When I went into forward gear, everything is fine until I try to give it some more throttle to get more speed. The throttle handle at 15 degrees to about 60-70 degree nothing happens. When I pass this 60-70 degree, I get into a quick trolling speed, that's all.
Anyone have any ideas?
Thanks,
Mike
  #2
Old September 16th, 2006, 08:22 PM
Plainsman's Avatar
Plainsman Plainsman is offline
Default Re: Mercury 850 - no power/speed
Do your RPMs increase as you give it throttle?
__________________
Rest in Peace Spinner
1978 SSV-176 Glastron with a 1976 115 hp model 1150 , 1972 Mercury115 hp
Your friend,your partner, your defender,your dog.You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion....by E.F. Henry
I am NOT a mechanic, but I did stay at a Holiday Inn Express
  #3
Old September 16th, 2006, 09:28 PM
ZaTech's Avatar
No not necessarily. I don't have a tach but by listening, for the speed that it's going, it is right. I would assume, like a car, if it revved up you'd be able to tell it's not right. So, I'd have to say it was fine with the speed it was going.
  #4
Old September 16th, 2006, 09:41 PM
Plainsman's Avatar
Have you checked for spark on all cylinder and a compression check of all cylinders?
__________________
  #5
Old September 16th, 2006, 09:47 PM
ZaTech's Avatar
If it were the spark, would I hear a difference in the motor, like misfiring or something odd? To me, as I said initially, it's purring like a kitten. I was very surprised actually. I will check the plugs tomorrow and also the compression while I'm at it. Is there a certain number I should be looking for on the gauge or should I look for concistency between the cylinders?
  #6
Old September 16th, 2006, 09:56 PM
Plainsman's Avatar
I can't answer your first question, but for compression,
over 100 and within 10% -15% of each other.
__________________
  #7
Old September 17th, 2006, 10:18 PM
ZaTech's Avatar
Checked the compression and all is good. They were all at 120. I'm taking the step further and I've taken out the carbs to clean them out. The boat had been sitting there for almost two years. I'm also going to clean out the gas lines. I've noticed that the fuel filter has some debris and also the same in the carb when I took them out today.
I'm sure it may be one cause of something. I'm still stumped with the throttle not giving me any thrust. Anyone with ideas?
  #8
Old September 17th, 2006, 10:55 PM
ricksrster's Avatar
ricksrster ricksrster is offline
What year and serial # is your motor?
1) When you get the carbs clean take it out and try it.
2) Try adjusting the motor tilt up or down a setting or two.
3) could be too much pitch on the prop.
4) could be the high speed winding an the stator.
__________________
"Many of the greatest sailors were pukers."--Thorfinn Skullsplitter
  #9
Old September 18th, 2006, 08:41 AM
Smig's Avatar
Smig Smig is offline
The same thing happened to me on my 850 - it was the carbs. Rebuilt, cleaned out and had to readjust one of the floats.
__________________
1976 Yar-Craft Eagle 16'-6" Tri-Hull
1976 Mercury 500 #436....
1976 Mercury 850 #442....
  #10
Old September 18th, 2006, 09:13 PM
ZaTech's Avatar
Smig, what happened to you was the no throttle issue? Did you have to adjust the throttle cable at all. As I said earlier in the posts was that the throttle arm at around 11 to 12 o'clock pushing forward to between 10 o'clock there is play in the throttle. Then just pass 10 o'clock the arms onthe motor begin to move but before that there's nothing. Only the sound that the motor is going into gear. By rebuilding the carbs (if this was your issue) fixed the problem??
  #11
Old September 19th, 2006, 04:48 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
assumming you have an inline 850, after rebuilding the carbs, do a linc and sinc, it is in the engine faq forum, by ClamsCasino. this put the electrical timing in sinc with the carb timing, so the work properly together,
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #12
Old September 19th, 2006, 09:42 AM
ZaTech's Avatar
That's great!! Thanks to everyone for their help. Maybe I do have one more chance to take the boat out for a spin before it gets too chilly up here in the north. I'll keep you all posted.
  #13
Old September 19th, 2006, 10:07 AM
Smig's Avatar
...what Tashasdaddy said. All of this stuff is related. After cleaning the carbs, I did a link and sync (which does include cable adjustment, but not until AFTER everything else is set correctly)
I'm too new to give you advice, but I will tell you what I did to get mine going. First I bought two manuals - an old OEM and a newer Clymer - didn't use either of their timing methods, but the pictures helped alot! I also had to do it in a logical order because there is so much going on (I am new to motors and still learning what to listen/watch for) This is the order I did it in - others can correct me, but I basically followed the fuel supply.
1) Made sure I had clean, good gas (with good oil and a good cleaner - I used sea foam)
2) Replaced the fuel bulb
3) Cleaned the fuel pump screen.
4) Cleaned the carbs (tore them apart - spray in the throats & jet wasn't good enough)
5a) Link and Sync (per Clams in the FAQ section - you can do most of it in your driveway)
5b) Finished link and sync at the water (you will know what I mean when you read it) I set the carbs a bit rich and the idle a bit high for the first test run.
6) For the next 2 or 3 outtings, I fiddled with the carb settings, the idle settings and the throttle cable preload, until I found the right combination that works for us (lots of trolling, in and out of gear, no-wake zones, starts and stops with the occasional WOT addrenal rush in between)
7) Still to do: I need to get the idle/pre-load dialed in after doing a decarb (it idles much better now), and rebuild the fuel pump, but I may wait until next season for those. I will also recheck the link & sync, because I will probably learn something new over the winter that I want to change!
So you know, these old mercontrollers are strange - at least both of mine are. The first 20 degress or so of handle movement, from 12:00 - 11:00 o'clock, only shifts from neutral to forward (800-600 rpm), then from the first timing event (11:00 - 9:30 o'clock on the handle, 600-3000 rpm, spark being advanced) is trolling speed stuff and then at the second timing event (9:30 - 8:00 o'clock, 3000-5500 rpm, max spark advance and the carbs really open up) the handle gets really, really stiff - I almost have to lean on it. All of the searches I did came back with the (very unsatisfying answer) that this is just the way they are. Next season I may mess with the cables, but first things first - get your motor running correctly so that it doesn't get burned by wrong timing or lean carbs!
I hope that helps, I know it's long winded and if I made a mistake - please, someone correct me!!!
Shaun
__________________
  #14
Old September 19th, 2006, 11:57 AM
ZaTech's Avatar
Thanks Shaun,
Everything you've mentioned, I either received an answer on this GREAT forum, also from my own "extensive" research on (dare I say it) other forums and also in the Seloc Manual. But you did mention a little more than others so every little bit counts and extremely helps.
One more little question, all of this can be done by one person or would it be easier with two? I'm thinking to crank the motor I'd have to remove the throttle and relocate it to the back of the boat so that I can turn the key and watch I need to watch...
Thanks again...
  #15
Old September 19th, 2006, 01:02 PM
Smig's Avatar
It is true - I have had to take some of my research elsewhere :'( until they get the search here fixed!! I hope it is soon!!
For me it took two - one to crank and then I did the adjustments. I actually needed both hands, one for the timing light and one to move the spark advance lever. On the water for carb and throttle cable adjustments, I still used two people, but mostly for safety - I wanted to have someone that could kill the engine if something went wrong, especially when checking the idle in gear.
BTW: What year motor do you have? All of my comments are based upon my '76 with the CDI ignition - I don't have a distributor.
__________________
  #16
Old September 19th, 2006, 03:56 PM
ZaTech's Avatar
1977 Mercury 850
Again, through this forum and everyones help, I received a link:
http://www.maxrules.com/graphics/mer...erc_page31.pdf
This shows the s/n and years for USA and Canadian motors. I was having trouble even with our local Mercury dealers trying to find the year. They all said that they couldn't find my serial number. The previous owners of the boat didn't have documentation but they did say it was a 1976.
As per my Seloc manual the specs of the '76 & '77 are, so far, similar.
Thanks,
  #17
Old September 19th, 2006, 11:08 PM
Smig's Avatar
In case you haven't found these yet, here are some good parts diagrams
__________________
  #18
Old September 26th, 2006, 04:13 PM
ZaTech's Avatar
Here's an update, I've taken the carbs apart, cleaned them, new gaskets and I'm ready to link and sync the carbs. The new question is that I have a 2 lead (a red and a black) tach tester. Where do I hook this up? The instructions show how to hook it up for vehicles but I can't see where I would hook it up on an outboard. Any ideas would really help?
Thanks,
Mike
**hurrying to get one last ride**
  #19
Old September 26th, 2006, 08:50 PM
Smig's Avatar
I don't think a car tach will work - they are for 4-strokes whereas you have a 2-stroke so it wouldn't be right and then there is the number of poles and this is where I get confused.???
I ended up buying a marine tach and setting the poles per the instructions. If you don't have one in the boat - get one. You will need it for timing the engine, propping it and monitoring it. RPM's tell you far more about your engine than speed. If I could only have one gauge it would be the tach...the only thing I can tell from my speedo is if there are weeds stuck on the pitot. d
Shaun
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
No power at high speed kmdneptune Johnson & Evinrude Outboards 0 August 8th, 2005 11:41 AM
speed/power CCSPDCOP Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 4 May 25th, 2004 09:08 AM
more power, speed JustinG Johnson & Evinrude Outboards 2 August 7th, 2003 06:14 AM
63 mercury 650 needs more speed-power dennis1980 Mercury & Mariner Outboards 1 May 15th, 2003 07:02 PM
Looking for HELP for more speed ,power & RPM SouthernWolf Boat Topics and Questions (not engine topics) 2 July 21st, 2002 09:35 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
