New to boating. My mom Gave me a boat she has had stored but not running for a year or so.
I bought a new marine battery, new tank and new gas with 50:1 oil mix
When I turn the key with it in nuetral it cranks very slow.
I think it might be stuck in FWD or REV? Would this cause it to crank really slow? I moved the shifter back and forth a few times to try to maybe "unstick it" from gear but that did not work.
When the shifter is in nuetral, should I be able to spin the prop freely? Because I can't...If I start turning the prop the flywheel on top also turns.
Any Idea what is wrong or what I should be looking at?
Thanks,
Carl
Thanks,
Carl
