Re: I hate my boat!
MrBigStuff;
Welcome to iboats!
We are the manufacturer of Smart Tabs and Mobster Tabs, and now ProTrollers.
Your comment regarding the Tabs being out of play at the top end leads me to believe that you may not be familiar with our design and function.
If the Smart Tabs and Mobster Tabs worked in the same manner as helm controlled Trim Tabs you would be 100% correct. Once the boat is at speed the tabs would be retracted.
However, Smart Tabs and Mobster Tabs do not use helm controlled electric or hydraulic actuators. We use a Nitrogen gas filled actuator which holds the trim tabs down at slow speeds then allows the water pressure to push then up as the boat increases speed. In the retracted position (at cruising speeds) the tabs continue to be under pressure and this creates enough stern left and control the ride and handling. For example, porpoising is eliminated, chine walking is eliminated and turns are more level and positive. The system is 100% active and similar to the suspension system on your car.
The increased speed comes from a few different things; 1) the smoother ride (no porpoising) allows you to trim the motor out to increase the efficiency. 2) the smoother ride allows the boat to build speed (bouncing creates a braking action). 3) since the lower pitch prop is not required for the hole shot (no hole to worry about), a higher pitch prop may be used.
Keep in mind that the system is always active.
In any event, our Tabs do allow the boat to attain more top speed. If you would like to talk to me directly please call our toll free number 800-233-0194.
