rockusilly
- Jul 4, 2006
- 1
I have twin Merc 1997 200 EFI,I spun the the hub on the port side motor so I repaced both hubs. Rpm,s were running the same before I replaced them, now the port side motor is showing 1000 rpm's higher the the starboard side even at low speed. It does not sound any higher by the naked ear. could it be bad tack, voltage reg. or something else. also this was the engine that spun the hub and it was at high speed but was backed down as soon as it happen but I don't know if anything could of happen in lower unit
